Re: Farmall M Compression
Posted by El Toro on June 17, 2004 at 18:04:05 from (205.188.117.22):
In Reply to: Farmall M Compression posted by Bart on June 17, 2004 at 01:29:44:
Hi Bart, I think JT may have found the problem.
The easiest thing to is pull the valve cover and see if the rocker arms move. I doubt if a metal timing gear stripped. GM had that problem years
ago using fiber timing gears and when they failed the push rods usually were bent.
You can probably get a good used cam
by advertising on here, since there is a lot of response on M Farmalls. Hal
PS: Ford even used plastic timing gears for a number of years. Suppose to run quieter.
Post a Followup
: Re: Re: Farmall M Compression
