Re: Charging problem 1950 cub- please help
Posted by El Toro on June 19, 2004 at 09:31:02 from (205.188.117.22):
In Reply to: Charging problem 1950 cub- please help posted by Ken Gray on June 18, 2004 at 13:28:38:
Use a multi-meter set on DC voltage across the battery posts with engine at a fast idle. If this still has the 6 volt system the meter should
read around 7 to 8 volts with that switch set on
H. If it has been converted to 12 volts the meter should read 13.5 to 14.5 volts. If you have
no charge shown on the meter it could be the regulator or the generator. Hal
Post a Followup
: Re: Re: Charging problem 1950 cub- please help
