Re: Leaky transmission seals
Posted by john *.?-!.* cub owner on June 21, 2004 at 10:30:50 from (209.142.136.38):
In Reply to: Leaky transmission seals posted by Jim Bowers on June 21, 2004 at 10:06:08:
Is it possible you put them in backward? Spring (or cupped side) should be toward the oil. Also did you oil the shaft where they run so they had a little lubrication while waiting for the transmission to sling oil on them?
Post a Followup
: Re: Re: Leaky transmission seals
