Re: Check M hydraulic level ?
Posted by Hermit on June 21, 2004 at 10:41:56 from (69.21.48.54):
In Reply to: Check M hydraulic level ? posted by Anthony on June 21, 2004 at 07:11:10:
You're probably looking in the right spot but a lot of those dipsticks have disappeared off the cap over the years, maybe into the reservoir. The top of the oil level is approx. 9 inches below the top of the filler neck (info in archives). You can make yourself a dipstick out of an old car dipstick bent and marked to the right length. There is a drain plug on the bottom of the lift-all unit. The reservior holds 6 quarts.
Post a Followup
: Re: Re: Check M hydraulic level ?
