Re: gas tank leaks
Posted by Haas on April 02, 2009 at 09:35:39 from (12.65.66.84):
In Reply to: gas tank leaks posted by Farmall Bob on April 02, 2009 at 09:14:39:
Depends how bad the leak is. My C tank was leaking around where the spot welds attached the brackets to the tank. I used a kit from Eastwood Automotive about 7 years ago. It's still holding with no leaks. Kit is not cheap though and you have to get acetone and muratic acid locally in addition to the kit. Important to follow the directions to the letter.
