Re: Belt Pulley Belt Lacing Question
Posted by Jeb2N on June 21, 2004 at 19:11:58 from (68.101.6.165):
In Reply to: Belt Pulley Belt Lacing Question posted by Scott L. Swanson on June 21, 2004 at 10:12:09:
Here's what you should know. There are two different types of lacing that are currently available readily. The first is called "Alligator" or "Flexco" lacing. This is one big long continuous strip of metal with big, jagged teeth on both sides. It comes with a "guage pin" that makes sure the loops are the same distance from the edge of the belt all the way across. You simply cut the strip as wide as your belt is, insert the guage pin, bump the clips up against the end of the belt and then hammer them in. This is the simplest form of lacing. The other type (sold at TSC) is called "Clipper" lacing, and it requires the use of a belt lacing press. The press isn't very expensive and is sold right there beside the clips. The clips look like individual hooks. You load the clips into little grooves in the press (which holds them in place and spaces them properly). A pin keeps them from falling out and keeps them spaced corrctly. Once you've loaded enough of them, you insert the belt into the jaws of the press (which sits in your bench vise, by the way) and then close the vice until the clips have dug into the belt sufficiently. The Clipper clips look much cleaner and are more flexible (going across the belt) than the alligator clips are. However, you need the press to install them. Your call. Come to think of it, I think TSC also sells the alligator (brand name) style as well. any place that sells flat belting will sell the clips and presses. NOTE: the clips are sized according to how thick the belting is. Make sure you know how thick your belt is so you get the proper size. Hope this has helped. Jeb
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
