Posted by Kendog on April 02, 2009 at 09:35:50 from (64.65.209.67):
In Reply to: gas tank leaks posted by Farmall Bob on April 02, 2009 at 09:14:39:
Use Red-Kote.
I spoke with a tech at Red-Kote and they advise not to use it on a tank with a baffle (like my Farmall-A), however I’ve done it successfully twice. The trick is to clean up the tank good (I poured in a small box of gun bb's and shook it to knock out the scale) and give a final rinse with MEK. Then dilute your can of RK with at least 50% MEK, pour it all in and rotate the tank methodically for a good skin layer. Dump out the RK but save it. Force air through the tank overnight, and tomorrow dilute the rest of the RK with a little more MEK , and pour it back into the tank for a second thin layer that will bond to the first. Drain and air out for a week + and let put it together!
Basically two 50% thinned coats (one can RK + 1/2 can of MEK) are MUCH better than one, and any puddles will dissolve and clog the system/filters. MEK can be purchased by the gallon at paint supply stores for $9 gallon. Don’t buy from $30 gallon auto shops, etc.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
