Farmall Tractors Discussion Board
Re: Restoring an H vs M
Posted by The Red on October 31, 1999 at 02:25:21 from (12.75.196.119):
In Reply to: Restoring an H vs M posted by Brian on October 30, 1999 at 17:55:31:
I really can't add much more to what has been said. Around my farm Ms are usually pretty worn out because they had a good 30 years of heavy farming. Hs didn't have enough power and a lot of them were delegated to lighter duty early in their life. My 1945 Indy H, for example, was basically retired from heavy farming in 1960. Since then it has pulled hoppers, wagons, and bush hogs and that is about it.
Post a Followup
: Re: Re: Restoring an H vs M
