Re: Block drain plug on H
Posted by ScottyHOMEy on April 02, 2009 at 09:40:19 from (71.241.194.27):
In Reply to: Re: Block drain plug on H posted by DTK on April 02, 2009 at 09:22:16:
It's obviously good sense to keep flame and spark away from any combustibles, including fumes. And it's always a good idea to have a fire extinguisher or two around.
But if you were to hit the surrounding area with a stiff brush and a solution of plain old Dawn dish detergent to clean away any grease oil, chaff and crud, and have the tractor in a place where you have a good noncombustible surface beneath and no fumes around, there shouldn't be any reason you couldn't heat it with a hand torch with Mapp or propane, and the heat WILL help a lot, almost to the point of being critical to success.
