Re: Farmall H not starting
Posted by Wayne Swenson on June 23, 2004 at 06:33:45 from (66.191.68.61):
In Reply to: Farmall H not starting posted by Bryan on June 22, 2004 at 21:17:43:
The H needs 3 things to start & run.
1. Fresh burnable fuel mixture delivered into the cylinders. (it ran so valves, manifold, etc. are likely OK) Check for good fuel supply at the carburetor.
2. Strong properly timed spark. Check the ignition output by pulling the center wire out of the distributor cap and hold it 1/4" from engine ground while someone operates the starter. Be sure the transmission is in neutral and brakes are applied.
3. Good compression. (ir ran so probably OK.)
Look for the simple things first.
Post a Followup
: Re: Re: Farmall H not starting
