Re: Re: Re: farmall H pto shaft
Posted by riverbend on June 23, 2004 at 20:21:46 from (208.160.33.94):
In Reply to: Re: Re: farmall H pto shaft posted by Eris Ripley on June 23, 2004 at 19:34:18:
Please, I am not familiar with text messaging. Use capitals and punctuation.
I would suggest that you buy a set of manuals before you go any farther. They will give directions on how to get the pto shaft out.
You might want to take a closer look because most of this stuff is pretty tough, usually it takes a lot of force to break something. You can see the end of the shaft, but how is everything else i.e. the countershaft bearing ? If you are going to fix it you might as well fix it right the first time.
Once you have it apart, try a tractor junkyard, or the dealer for parts.
Post a Followup
: Re: Re: Re: Re: farmall H pto shaft
