Re: Re: Re: Re: 49' M fuel/timing question
Posted by rustyfarmall on June 24, 2004 at 11:16:21 from (216.248.75.136):
In Reply to: Re: Re: Re: 49' M fuel/timing question posted by jamie on June 24, 2004 at 08:37:32:
Yes, mine does it in hot, humid weather also. What I was getting at is the fact that it will also occur in cold, damp weather, and then you have a problem with frost forming both on the outside of the carb, and the inside of the intake. The engine will run very poorly when this happens.
Post a Followup
: Re: Re: Re: Re: Re: 49' M fuel/timing question
