Re: Timing question?
Posted by gene b on June 25, 2004 at 01:16:27 from (67.1.105.94):
In Reply to: Timing question? posted by Don on June 24, 2004 at 19:51:13:
If the rotor lines up with #1 post on the cap and trips when on TDC there is no further timing as the mag will go to 34deg advance when running. The impulse will click when you turn the engine over with a crank as each piston reaches TDC. Firing order is 1342 and the rotor turns clockwise. #1 is around 1 oclock position.
Post a Followup
: Re: Re: Timing question?
