Re: farmall A smokes
Posted by Stan(PA) on June 25, 2004 at 06:24:26 from (69.166.59.75):
In Reply to: farmall A smokes posted by jimmy on June 25, 2004 at 06:05:09:
If the smoke was black, it would be easily understandable as too much gas (choke) on startup. If it's blue, my guess is oil seeping past the valve guides when it sits for awhile. I'm guessing that if you shut her down, and restart in 5 or ten minutes, there ain't much smoke. I could be wrong, but if she runs good, I wouldn't worry too much about it. If your plugs start fouling fairly often, pull the head and get the valves redone. You can also do a compression test to make sure rings are good, but it really sounds like valve guides to me.
Post a Followup
: Re: Re: farmall A smokes
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
