Re: 706 PTO slips
Posted by the tractor vet on June 26, 2004 at 17:16:39 from (216.196.13.70):
In Reply to: 706 PTO slips posted by Arnie on June 26, 2004 at 00:26:14:
If you are going to work on it then ya need to get a spec. fitting so you can set the pressure and if ya are going to put clutches in it you will need to make a compression dell to compress the brake springs so you can put new seals in the piston use the H/D clutch pack with the 7 and 9 set up set the pressure at 245 to 260 and you will never slip them again.
Post a Followup
: Re: Re: 706 PTO slips
