Re: Flywheel and Pressure plate bolt torque spec
Posted by El Toro on June 27, 2004 at 05:09:26 from (205.188.117.22):
In Reply to: Flywheel and Pressure plate bolt torque spec posted by Red Rookie in Wi on June 25, 2004 at 15:44:55:
Hi Red, Call your local IHC service department
and they can supply those torques. You could probably use the bolt torques from a machinist's
handbook, depending on the size of those bolts.
I would call the dealer to be on the safe side. Even Yesterday's Tractor may be able to supply those torques. Hal
Post a Followup
: Re: Re: Flywheel and Pressure plate bolt torque spec
