Re: block drain plug on H
Posted by Maniak on April 02, 2009 at 10:31:19 from (65.166.205.9):
In Reply to: block drain plug on H posted by DTK on April 02, 2009 at 06:01:39:
I gave up on ez outs years ago.. I just don't have the knack for it, I kept breaking them.
The closest I use now are left handed drill bits. More often than not as I'm going up in drill sizes the drill bit grabs and turns the broken bolt (drain plug in this case) out.
sort of like what was mentioned above but what I'm using is just a drill bit. That tool mentioned in the post above may work even better. Worst case, Its drilled out and then I tap the hole.
~Mark
