Re: 1971 IH 154 lowboy: Buy or not?
Posted by K-Mo on June 28, 2004 at 04:43:17 from (65.169.189.2):
In Reply to: 1971 IH 154 lowboy: Buy or not? posted by Tracy Sund on June 27, 2004 at 21:51:40:
This are great little tractors. On the low side, PTO and Drive clutch need frequent maintenance and the turf tires are short on traction for other jobs.
For some reason, IH put the drive clutch on the transmission instead of the engine. To stop the transmission from spinning with the clutch engaged, a brake is engaged. If this brake is not properly adjusted, you'll grind gears when you shift.
There are a coup[le of versions of the PTO clutch. At least one required the removal and disassembly to adjust it.
The the drive and PTO clutch systems were improved on the 184 models.
Great tractor. Price sounds reasonable.
Kent (154/184)
Post a Followup
: Re: Re: 1971 IH 154 lowboy: Buy or not?
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
