Re: Re: Re: Farmall B sleeve question
Posted by Ed on June 28, 2004 at 21:00:50 from (216.93.26.84):
In Reply to: Re: Re: Farmall B sleeve question posted by Kenneth on June 28, 2004 at 20:02:02:
without spending alot of money on bore gauges, you can measure the ring gap at the top of the bore (ring travel)...and then using the same ring , measure the ring gap at the bottom of the bore (ring travel)....if the measurements are close , you'll be fine.....you can also slide feeler gauges next to a piston that does'nt have rings installed on it yet, at a few different spots in the bore
Post a Followup
: Re: Re: Re: Re: Farmall B sleeve question
