Farmall Tractors Discussion Board
Re: trailering a tractor
Posted by Charlie V - AKA F20II on October 31, 1999 at 21:41:59 from (207.202.172.160):
In Reply to: trailering a tractor posted by 100Glenn on October 31, 1999 at 13:18:49:
ratching chain binders are very good but also very expensive, regular brake-over chain binds will do the job quit well and cost less than the others. Use a small lenght of pipe on the binder when tighting the binder down and you should have no problems. Just look where your placing your chains so you don't break anything. I always chain thought the wheels front and back, using old rubber tubs between the chains and wheels, that's when I remember the rubber. You don't have to put rubber between them, it's only to prevent marking up the paint. Have fun and above all be safe. :-)
Post a Followup
: Re: Re: trailering a tractor
