Farmall Tractors Discussion Board
Re: fast hitch for super c
Posted by Stan(VA). on November 01, 1999 at 05:11:16 from (207.79.164.6):
In Reply to: fast hitch for super c posted by ronnie h on October 31, 1999 at 20:46:23:
If you're sure it's a 200 and not the 230, then yes it'll fit. The SC and 200 fast hitch will fit the C/SC/200 and have 3 angles of hydraulic control. Make sure you get the new rockshaft arm on the right with the extra connection on the back of the shaft. This connection is often just linked to a stud on the clutch housing to hold a fixed angle (front to back). It's a pipe that slides out a 2nd part to reach up to the rockshaft arm. On the left side you have a long arm with multiple bends that connects to the inner rockshaft to provide side to side tilt.
The bottom of the 230 transmission housing is shapped different and protrudes down farther to where the fast hitch attaches differently in the front, and it doesn't have the rockshaft that goes through the seat housing like the SC/200 hitch has.
The hardest part is either pulling the seat box with the cutouts for the rockshaft or using a hole saw to cut matching holes in your seat box. Other than that everything just bolts up. You will need the remote hydraulic valve, handle, and manifold from the 200 as well.
Stan(VA).
Post a Followup
: Re: Re: fast hitch for super c
