Re: Timing a B
Posted by Dave_Id on June 30, 2004 at 15:08:01 from (66.82.9.49):
In Reply to: Timing a B posted by GeoMo on June 30, 2004 at 14:47:57:
Geo, what you have to do is loosen the mag, push it up against the engine. Remove #1 plug, crank by hand until compression pushes thumb out of #1 plug hole. Now if you remove inspection plate, timing mark should be visible. Continue to crank engine until timing mark is lined up with the pointer. When this is done, slowly pull mag away from engine until you hear a snapping sound. Tighten mag, engine is now timed
Post a Followup
: Re: Re: Timing a B
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
