Re: Re: M starting problem
Posted by El Toro on June 30, 2004 at 16:57:10 from (205.188.117.22):
In Reply to: Re: M starting problem posted by captaink on June 30, 2004 at 11:08:00:
Hi, Does the tractor smoke when it does start? If
it smokes a lot during the inital startup it is probably the carb. leaking fuel. If you have to choke the engine a lot to get it started the engine may be starving for fuel. I always shut the fuel off when I finish with the tractor for the day. Being gravity fed there's a lot of weight from a full fuel tank pushing against the
float needle valve. Hal
Post a Followup
: Re: Re: Re: M starting problem
