Re: Hard Steering H
Posted by Bob M on June 30, 2004 at 19:09:34 from (66.67.11.95):
In Reply to: Hard Steering H posted by Jeff C. on June 30, 2004 at 13:38:33:
Expanding a bit on the posts below, some possibilities: 1 - Failed thrust bearing on the bottom of the bolster pivot shaft (carries the weight of the front half of the tractor). This can cause the bolt heads fastening the lower bolster to the pivot shaft flange to scrub against the underside of the fixed bolster. Also can cause the top of the pivot shaft to rub rub on the underside of the steering gear pot cover. 2 - No lube in the steering pot - causing excessive drag in the worm gear set and pivot shaft bushing. 3 - Bent pivot shaft. Suggest taking the load off the front wheels by jacking the tractor at the clutch housing. If the steering frees up the problem is #1. If it's still stiff suspect #2 or #3. Or simply remove the cover from the steering pot and peek inside. What you see will let you figure out pretty quick where the problem is. Good luck!
Home
| Forums
Today's Featured Article -
Memories of an IH Super A When I was ? up to 10, I worked on my Papaw's farm in Greeneville, TN every summer. As I grew older (7), it was the thrill of my day to ride or drive on the tractor. My Papaw had a 1954 IH Super A that he bought to replace a Cub. My Papaw raised "baccer" (tobacco) and corn with the Super A, but the fondest memory was of the sawmill. He owned a small sawmill for sawing "baccer" sticks. The Super A was the powerplant. When I was old enough (7 or 8), I would get up early and be dressed to
... [Read Article]
Latest Ad:
Variable pulley for case 1530 skid loader
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
