Re: Timing a B
Posted by Steve W (NY) on July 01, 2004 at 05:46:33 from (24.213.210.222):
In Reply to: Timing a B posted by GeoMo on June 30, 2004 at 14:47:57:
Just been there....see my post from a few days ago. It's unlikely the camshaft is out of position from crank, but if you remove the governor, the drive gear for the governor (front) and magneto (back) comes right out. I said "hey that's cool", then realized oops! now I got to figure out how to time it. There are two sets of dots on the cam shaft 180 degrees apart. The single dot on the canshft gear needs to match up with the single dot on the crankshaft. If this is done, the opposite two dot mark will be in a position where the governor gears two dot marking can match it. Kind of a slick and simple set up. Of course on a B (or an A) taking off the front end to get behind that cover is a problem. No big deal. Just take off the governor (5 bolts) and then watch very carefully as you turn the crank (take out the sparkplugs and use a hand crank) until you see the two very faint dots. Make sure you see two. Then look closely at your governor drive gear for the two dots and slip them together. Done! Put it all back together, and you are "timed". Now that assumes your crank and cam have never become misaligned, but that's a pretty good assumption unless grandpa really tore into her. At this point, you can still put the magneto on wrong, but if you bring it up to TDC on the compression stroke, and then pup off the mag cap and point the rotor to no 1, you'll see how it goes together. Good Luck Steve
Home
| Forums
Today's Featured Article -
Check Your Coolant - by Bill Radford. Great tips on how and when to check the coolant in your tractor.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
