Farmall cub hydraulics
Posted by Layton on July 01, 2004 at 08:55:00 from (69.72.39.185):
I just rebuilt the hydraulic pump on one of my cubs(1949). When the the lever is moved forward the ram extends slowly, but must be pushed back by hand. Is this caused by air in the lines and how do I successfully bleed them? Thanks
Post a Followup
: Re: Farmall cub hydraulics
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
