Re: Super A not running
Posted by Kendall on July 01, 2004 at 15:26:25 from (67.65.89.57):
In Reply to: Super A not running posted by Jon on July 01, 2004 at 13:59:44:
Its easy to mess up the installation of the distribuitor and get the timing off. If yours is a distributor& coil ignition, heres how to set the timing: Align the timing mark located on the flywheel with the mark on the housing so that #1 is at TDC. The timing mark is a line with "D-C" & "1-4" on either side. Its is very faint and may be hard to find if you flywheel is dirty. Use a flashlight. Remove the spark plugs and have a helper turn the engine with a crank. The indicator on the housing is at the very bottom. You can see all this through the hole on the bottom of the clutch housing. Once this is done, make sure the distributor's rotor is pointing toward #1 plug wire. If it's not, remove and reinstall it so that it is. Now retard the timing by rotating the distributor in the same direction that the cam rotates so that the points are closed, and with the hot/center wire of the coil near a ground, advance the timing by rotating the distributor back the other way slowly until the points just open and a spark occurs. (the distributor sparks when points open) Lock the distributor down there. This is the correct setting for your engine and the rest of the timing advance occurs in the distributor with the mechanical advance.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
