Re: Super A not running
Posted by Ron in Nebr on July 01, 2004 at 16:07:19 from (65.172.143.226):
In Reply to: Super A not running posted by Jon on July 01, 2004 at 13:59:44:
The other posts about the timing are most likely the problem, but another thing could be that if the cylinder head was surfaced the valve clearance may be too tight and not letting the valves close completely.
It doesn't take long to adjust the valve lash on a 4cyl, so, since you haven't done it yet anyway, it'd be a good idea to do that at the same time you check/set the timing.
Post a Followup
: Re: Re: Super A not running
