Re: Super A not running
Posted by El Toro on July 01, 2004 at 17:08:59 from (205.188.117.22):
In Reply to: Super A not running posted by Jon on July 01, 2004 at 13:59:44:
Hi Jon, Good advice from Ron, check that valve
lash for enough clearance. They recommend .014H
on the valves. Set them to .016" until you get the tractor started. You can readjust the valves
later to .014". The valves may not have enough
clearance for the valves to close fully on the compression stroke. A valve too tight may cause the engine to miss. Good Luck, Hal
Post a Followup
: Re: Re: Super A not running
