Re: Re: Re: Model A engine block I.D.
Posted by Stan(VA). on July 02, 2004 at 10:25:57 from (208.59.157.67):
In Reply to: Re: Re: Model A engine block I.D. posted by James Moore on July 02, 2004 at 07:42:46:
James,
Yes, those should fit fine. The two measurements are roughly 3-5/16" or 3-7/16", so the biggest you can use is the 3-1/8" overbore kit in your motor.
Thermocoupler? If you are saying your upper radiator neck off the cyl head has a temp sending unit, OK. If you are running w/o a water pump, then make sure you have the older style C-113 head gasket with the large openings in the water jackets, and you shouldn't have a thermostat.
Stan(VA).
Post a Followup
: Re: Re: Re: Re: Model A engine block I.D.
