Re: Gas Leak in BN
Posted by El Toro on July 02, 2004 at 18:42:10 from (64.12.117.22):
In Reply to: Gas Leak in BN posted by Jeff_MI on July 02, 2004 at 04:55:09:
Hi Jeff, I 'll give you the different fluids that you can use the Gasoila thread sealant on. It can be use on gasoline, oils, kerosene, diesel fuels, steam, refrigerants, natural gas, butane and propane. The Gasoila has a soft-set so you can remove fittings easily. I've used permatex, but this is better. You can get a small can that contains 1/2 pint. I think I only paid 5 or 6 dollars and you can coat a lot of fittings with this small can. Good Luck, Hal
Post a Followup
: Re: Re: Gas Leak in BN
