Re: 55 300 Utility... off to the boneyard?
Posted by TDK on July 04, 2004 at 14:17:36 from (152.163.253.103):
In Reply to: 55 300 Utility... off to the boneyard? posted by Dave on July 04, 2004 at 13:41:30:
Dave, the H(152),Super H(164),300 Farmall or Utility(169)& 350 Farmall or Utility(175) engines will fit in your 300U. The H & S/H engines have less horsepower though and you'll have to swap the front crankcase cover,plate,etc. from the 169 engine in order to mount hyd. pump. The mounts will also have to be swapped from the H, S/H,and Farmall 300,350 engines. You should be able to find one of these.
If you decide to part out the tractor please send me an e-mail, we have a couple we're restoring. Good Luck.
Post a Followup
: Re: Re: 55 300 Utility... off to the boneyard?
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
