Re: Re: 53 super A on/off switch not working...HEL
Posted by Bob M on July 05, 2004 at 19:24:55 from (66.67.11.95):
In Reply to: Re: 53 super A on/off switch not working...HELP! posted by patpeery on July 05, 2004 at 18:13:21:
As Hugh suggests above if your tractor has an alternator conversion and the wrong size warning lamp bulb was used (or if the conversion is wired wrong) it will do exactly as you describe!
Post a Followup
: Re: Re: Re: 53 super A on/off switch not working...HEL
