Re: Super A not running
Posted by the firing order is not 1 on July 06, 2004 at 03:29:12 from (4.41.99.214):
In Reply to: Super A not running posted by Jon on July 01, 2004 at 13:59:44:
thats a comon mistake just didn't want you to over look it!!
after that pull #1 plug roll ever by hand tell you feel air coming out this is the compression stroke now put wire in hole tell you get piston to the top then make shure the rotor is pointing at #1 termal on cap or the termal that is the wire of #1 plug then note rotor turns clockwise start with the termal that the rotor is pointing at when #1 cyl is at TDC put #1 wire on that termal in the clockwise direction put #3 on next then #4 then #4 on the last one
Post a Followup
: Re: Re: Super A not running
