one cylinder replace on d 282
Posted by Chris Brown on July 06, 2004 at 18:40:26 from (209.206.208.57):
I just tore down a d282 in a 560 I just got. It was stuck and I did the usual soak and rock till it turns trick,well I broke one sleeve and piston. I have some good used ones saved from previous junk.All the other pistons fit tight and all the bearings are good. Should I just poke one sleeve and piston in it and see how it runs? I have a piston and sleeve kit,but I hate to just waste it if it is really not needed.
Have any of you put in one sleeve and piston?
Also does anyone know of a place to get a head gasget set for less than $85.00
Post a Followup
: Re: one cylinder replace on d 282
