Re: Re: Re: Re: ? size rotary mower for a 'M' ?
Posted by CNKS on July 06, 2004 at 18:48:59 from (207.178.96.211):
In Reply to: Re: Re: Re: ? size rotary mower for a 'M' ? posted by souNdguy on July 06, 2004 at 06:26:14:
The key word is thick -- like a lawn, only 2 feet tall, not ordinary grass and weeds. I was merely pointing out that you can bog anything down if conditions are severe enough. Highway depts used to use Farmall A's or Allis C's (don't know the model number) with belly mowers, worked pretty good. In general an M will easily pull a 7 foot mower, likely you will have no problems.
Post a Followup
: Re: Re: Re: Re: Re: ? size rotary mower for a 'M' ?
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
