Re: H governor repair
Posted by mbnok on July 06, 2004 at 20:50:56 from (216.226.31.8):
In Reply to: H governor repair posted by haymeadow52 on July 06, 2004 at 19:30:33:
Parts should be available at your caseIH dealer. Watch for the washer that runs between the "spool" and the weights it must be smooth, they will get groves in it, you can turn it around if the other side is smooth. the area of the weight (lever) that pushes on this washer will get flat,sometimes you can carefully grind this back to a curved look it will help if you have a new one to look at. I have drilled the holes out if there not to bad and put grade eight bolts in for pins. you have to cut the end off a little to get them in.
Post a Followup
: Re: Re: H governor repair
