53 Super A on/off switch follow up
Posted by patpeery on July 07, 2004 at 20:20:14 from (64.12.116.14):
i noticed the switch would not cut off after i had hosed the tractor off following a muddy field day. i did not spray the switch or around the battery directly, just the tires but as you know it splashed up a little. could this be causing the problem? water in the switch causing it not to turn off? if so can this be dried out?
Post a Followup
: Re: 53 Super A on/off switch follow up
