Re: Should go electronic ignition on old Farmalls
Posted by Bob M on July 08, 2004 at 06:30:28 from (165.170.128.66):
In Reply to: Should go electronic ignition on old Farmalls? posted by Wayne in Iowa on July 08, 2004 at 05:05:54:
Wayne - My experience is the stock IHC ignition system is pretty robust. So long the distributor is kept reasonably clean and dry inside it’ll give many hundreds of hours of service without attention. And the stock system provides reliable starting and running in virtually all conditions – just like the original designers intended. About the only situation where electronic ignition offers an advantage is high performance service such as pulling - electronic ignition’s higher output voltage makes it better suited for high compression/high RPM than the stock system. Also electronic ignition eliminates the need for periodic breaker point adjustment/replacement, just as you suggest. However it being electronic, electronic ignition is susceptible to failure from voltage spikes, reversed battery connections, wiring errors, etc – things which have no effect whatsoever on a stock ignition system. And electronic ignition kits are not exactly cheap! Bottom line: Unless you are into competitive pulling in the modified classes you’ll be fine with the stock system. Simply make sure the distributor is clean inside and is sealed up well (to keep dirt, oil, water, etc out) - it’ll work fine for you.
Home
| Forums
Today's Featured Article -
Dad's Old Silver King and Joe Capalco - by Woody E. Diehl. My father, Charles Diehl, grew up in the Elsworth, Ohio area during the Depression on a small working farm. I never saw the place, nor was I around during his early years. What I know about those hard times comes from listening to Dad and his old pals reminisce from time to time. One of the old timers that would sit with Dad and chew the fat about the 'good ole days' was Joe Capalco. Joe wasn't like most of my Dad's friends. He rarely worked that we knew of. Always had plenty of time
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
