Re: H distributor plate marks - possibly for Dave
Posted by ChadS on July 08, 2004 at 09:53:50 from (66.228.96.200):
In Reply to: H distributor plate marks - possibly for Dave WV posted by Dave in CT on July 08, 2004 at 09:40:48:
I have drilled the hole out a bit larger to change the amount of advance the mechanism outputs. Usually, when you have the rotor on, you should be able to turn the rotor to activate the mechanical advance, should turn maybe 1/4 to a half inch of movement on average. Is it a vertical distirbutor, or a horizontal distibutor, delco, or IH?? I have several of both apart,, all off gas models, H and M. Another way to measure the plate is to use a set of calipers to measure the hole sizes, smaller, means less advance, larger, more advance. Maybe drill the one you have to match the one you need??? ChadS
Post a Followup
: Re: Re: H distributor plate marks - possibly for Dave
