Re: Farmall B Generator Output????
Posted by Bob M on July 09, 2004 at 05:38:12 from (165.170.128.65):
In Reply to: Farmall B Generator Output???? posted by Red-Ed on July 08, 2004 at 17:32:51:
Ed – If the generator is good and if your B is equipped with stock cutout relay, with the engine running at full speed the ammeter should indicate 2 – 3 amps charge with the light switch set at “L”, and 12 – 15 amps when set at “H”.
However if the cutout’s been replaced with a voltage regulator (which often happens) the ammeter should show 12 – 15 amps at startup then gradually taper off as the battery charges up.
How to diagnose your B's "no charge" problem depends on whether you have a cutout or regulator. Here’s URL’s to a couple troubleshooting charts that might be helpful:
Regulator:
http://albums.photo.epson.com/j/ViewPhoto?u=4001561&a=30065733&p=63426275
Cutout:
http://albums.photo.epson.com/j/ViewPhoto?u=4001561&a=30065733&p=66886188
Hope this helps...
Post a Followup
: Re: Re: Farmall B Generator Output????
