Farmall Super C Front Crank Pulley Removal
Posted by Joshua Blauvelt on July 09, 2004 at 10:21:17 from (199.197.135.1):
I have read through the past posts about removing the front pulley on the crankshaft and tried all the suggestions. I have used a steering wheel puller with a bracket behind the crankshaft pulley to keep the load evenly distributed throughout the pulley and reefed on it something fierce yet it didn't even budge. Then I tried adding heat, LOTS of heat and still nothing. It has been soaked daily in penetrating oil and that still doesn't help. I actually broke a 3/8" Husky drive AND 3/4" deep well socket I was ranking so hard. Several posts say this is easy, and the manual I have makes it sound like it is easy as blowing out birthday candles. I have tried just about everything I can think of. Does anyone have an suggestions other then cutting it off? Thanks Josh
Post a Followup
: Re: Farmall Super C Front Crank Pulley Removal
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
