Re: Wiring Diagram for Super M with Factory LPG
Posted by Bob M on July 10, 2004 at 10:10:32 from (66.67.11.95):
In Reply to: Wiring Diagram for Super M with Factory LPG posted by w6tractor on July 10, 2004 at 07:22:57:
Hey W6... I'm not familiar with the LPG SM, nor do I have a wiring diagram for it. I'd suspect however it was originally equipped with a manual (pull rod) starter switch, then subsequently changed over to a pushbutton/solenoid configuration later - though that's just a guess.
Anyway the solenoid circuit wiring is straightforward: From the hot side of the ignition switch, run to either terminal on the push button, then from the other pushbutton terminal to the small terminal on the solenoid. (Or to the small terminal labelled "S" if the solenoid has 2 terminals...)
Does this help?
Post a Followup
: Re: Re: Wiring Diagram for Super M with Factory LPG
