Re: Bad Luck Again
Posted by Hugh MacKay on July 10, 2004 at 15:36:59 from (209.226.106.117):
In Reply to: Bad Luck Again posted by Jeff In Ontario on July 10, 2004 at 14:02:51:
Jeff: You probably have some problems right in the top cover. Your shift lever works 3 slideing rails in there one for reverse, 2nd for 1st and 2nd and the third for 3rd and 4th. There are detent balls and springs holding those rails in position. They can do one of two things not hold or not let go. One of the problems I've found with these detent balls and springs, is if tractor sits for long periods no oil get up around top and you get rust. Those balls and springs are still available from CaseIH.
From those rails forks go down to sliding gears, so problem could be down there as well. Just take the top cover with the shift lever out, you should see it. It is a bit tricky putting cover back on as the forks must align with gears. It can go on without forks being in alignment. Be careful on that one.
Having said all of this I am assuming A is same as SA, 100 and 130.
Post a Followup
: Re: Re: Bad Luck Again
