Re: 460 trans shifter forks
Posted by K.B. on July 11, 2004 at 19:45:14 from (209.163.30.20):
In Reply to: 460 trans shifter forks posted by gwece on July 11, 2004 at 09:37:00:
The end of your shift lever is most likely worn. Build it up with the welder, then grind it down to shape. You want it to fit the notches in the shift forks with as little play as possible.
Post a Followup
: Re: Re: 460 trans shifter forks
