Re: Farmall C Carburetor Question
Posted by captaink on July 12, 2004 at 10:46:09 from (66.115.212.249):
In Reply to: Farmall C Carburetor Question posted by Scott Swanson on July 12, 2004 at 09:59:36:
You are probably correct that it is running too rich. Check to make sure that the needle and seat are sealing, there is not gas in the float and that the float level is set correctly. If all that checks out I would suggest that you take the intake hose off the carburetor and see if that makes it speed up. If it does, you have a restriction in the air cleaner/intake pipe somewhere. The only way that I know of to lean up carburetors without mixture screw adjustment is to put in different size jets.
Post a Followup
: Re: Re: Farmall C Carburetor Question
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
