Re: Re: Swaping M/SM clutch and pressure plates
Posted by Aces on July 12, 2004 at 12:43:25 from (67.0.38.13):
In Reply to: Re: Swaping M/SM clutch and pressure plates posted by RPM on July 12, 2004 at 11:28:32:
The SM's had inch bigger clutch than M never had to split the M's to replace clutch but had to split SM's to replace clutch because of inch bigger clutch. IF THE HUB on M cranshaft dor the flywheel is the same as SM I din't see why it would not work The late M's had same bearings as SM so maybe the flywheels will inter change.
Post a Followup
: Re: Re: Re: Swaping M/SM clutch and pressure plates
