Re: Re: Re: Farmall 100 grinding gears
Posted by scotty on July 13, 2004 at 13:00:00 from (199.231.49.128):
In Reply to: Re: Re: Farmall 100 grinding gears posted by Ramon from NC on July 13, 2004 at 11:12:54:
Ramon,
As you sit on the tractor, to your left, you will see the arm that is attached to the left brake lever. Just below that arm is a pipe plug, take that plug out while the tractor is on level ground. The transmission fluid should be level with the bottom of that tapped hole. Also, Ben mentioned the weight of the gear lube you are using. I use 90wt. By using a heavier weight lube you will slow those gears down to some degree making it easier to get into gear.
scotty
Post a Followup
: Re: Re: Re: Re: Farmall 100 grinding gears
