Re: Super A mower question
Posted by Thomas C on July 13, 2004 at 15:33:31 from (63.155.244.102):
In Reply to: Super A mower question posted by Bill in VT on July 13, 2004 at 09:34:47:
Bill,
While I have seen a number of belly mowers run with a V-belt pulley on the belt pulley shaft, mine came with a V-belt pulley about 12" in diameter for the PTO shaft. This size pulley gives me the same blade tip speed as a smaller pulley on the belt pulley shaft. There are 2 adjustable idler pulleys mounted on a bracket bolted to the drawbar studs that turn the belt 90 degrees and then down to a pulley on the mower.
Tom
Post a Followup
: Re: Re: Super A mower question
