Re: Farmall 100 grinding gears
Posted by Hugh MacKay on July 14, 2004 at 02:39:00 from (216.208.58.164):
In Reply to: Farmall 100 grinding gears posted by Ramon from NC on July 13, 2004 at 09:12:23:
Ramon: Haas has the proper ideas for diagnosing your problem. It could well be your transmission oil too light, could be your release bearing or could be pilot bushing. Release bearing if bad should make noise when ever clutch is depressed. The pilot bushing if bad will make its noise when clutch is depressed and tractor is in gear. Note the difference in those two statments.
Post a Followup
: Re: Re: Farmall 100 grinding gears
